D6 oil pan troubles
D6 oil pan troubles
16 years 8 months ago #12239
by sodbuster25
I'm working on a 1952 D6 dozer. I am having a problem getting the oil pan off the block. I have all the bolts out and I drove the dowel pins out. I have beat on it, pryed on it, and tried to drive a wedge between the block and the pan and it still wont move. Any ideas?
16 years 8 months ago #12244
Are you sure you got all the bolts?
There are:
30 -7/16 x 1-1/8 pan bolts
4- 1/2 x 1-1/2 bell housing bolts
7- 3/8 x 1-3/4 bolts into the timing cover
With all these out it's a clear drop but you have to drop or remove the equalizer spring bracket to get it out.
16 years 8 months ago #12253
by sodbuster25
Thanks for the reply! It is inside in the heat! Do all of the bolts that screw into the timing cover come up from the bottom?
16 years 8 months ago #12254
Yes, all from the bottom.
Are you sure on the year model??? the earlier D4600 "R" series tractors have some "juggle" requirements to get the pan off.
16 years 8 months ago #12255
by sodbuster25
serial # is 9U10453. I was told its was a 1952. Is that right? I will check the bolts again in the morning. This thing just will not break loose! Thanks
Thank you received: 12
16 years 8 months ago #12262
by brian18a
Sure someone did not glue it on with something like Cat super gasket cement, if so it is almost impossible to get things apart.
16 years 8 months ago #12263
Year and model is correct.
Pull the side covers off and have a look in there to see if anything is hanging it up. I'm stumped:confused:
Are all the bolts accounted for??
16 years 8 months ago #12304
by sodbuster25
Turns out it was just the gasket that was glued on! I used the torch to burn the gasket out and then soaked it with WD-40. After about 2 hours with a pry bar, the pan finally broke loose! Thanks for all the help!
D6 oil pan troubles
Time to create page: 0.154 seconds
