5 Day Dozer
5 Day Dozer
16 years 10 months ago #11048
by carlsharp
For those of you following along, this Cat should be like a nephew by now. It first started with the "D4 on ebay HELP NOW" thread, and then in "Single Cylinder D4".
In KoO fashion it is now known as "The Nudist" because it was found stripped at a nudist colony.
Now I have a running main engine, 5 pallets of parts, and a playday in 5 days. It was supposed to be fully functional when they took it apart.
Do you think I can have a dozer by then? Follow along and see.
16 years 10 months ago #11049
by carlsharp
Got it running, got it home.
Drained the trans/bevel case (water in oil)
Adjusted main and steering clutches
Adjusted steering brakes
Replaced covers on rear (5)
Greased some
Install drawbar
16 years 10 months ago #11050
by carlsharp
Picked up woodruff key and set screw for hyd pump shaft
Installed:
All floor tins
Fan shroud
Grille
Clutch cover/throttle link
Hyd pump (took the torch to get the nuts off the studs)
Hyd tank/valve
Hyd lines (loosely)
Hyd rams
All this after working all day...
16 years 10 months ago #11054
by gwhdiesel75
Carl, glad to see your progress. Why to heck did that "strip" the tractor? Keep up the good work and keep the photos coming. GWH
16 years 10 months ago #11079
by carlsharp
Picked up new hose for hyd supply. $14 a foot!!
Installed ^ hose
Tighten and mount hyd lines
Drain finals, fill w/diesel
Man what a pain. The hyd supply to the pump is hard lined with 5 els including one homemade with a 'special' angle. Took like 2 hours to get everything to line up. Plus nine unions to make up.
16 years 10 months ago #11088
by carlsharp
R & R valve cover, replace gasket
Flush/fill finals
Fill hyd system
Drag start, cycle hyd's, everything works! 2 hoses leak
Get hoses made, R&R
Refill hyd's
Install hood, muffler, precleaner
Make a 2 5/16 pin out of 2 3/8 stock- with a grinder!
Install dozer frame, blade and angle struts
Attach lift links
Believe it or not....
Ladies and gentlemen, I am proud to introduce..
The FOUR day dozer!!!
5 Day Dozer
