DW Series tractors in agriculture ?
Thank you received: 285
16 years 10 months ago #11016
by gauntjoh
I've often wondered if Caterpillar DW10 / 15 / 20 series tractors were ever supplied for use in agriculture, and if so with what type of equipment ?
Does anyone have any information or pictures of their use in agriculture ?
A 115 HP tractor in 1947 in use on the land would have been most impressive.
16 years 10 months ago #11022
by ronm
I've seen old pictures of sugar cane farms in, I believe, Hawaii, that used rubber-tired Cat tractors. May have been used in Louisiana too, I don't know.
Thank you received: 5
16 years 10 months ago #11038
by catskinner
Back in the late 60's I would guess, there was a farmer over by Genesio, KS that used a DW 20 to farm with. I don't know that I actually seen it working in the field but I've seen it sitting in the field close by the road and I don't remrember what it was pulling. I never really paid that much attention to it and it was about 20 some miles away and only went by it once in a blue moon. catskinner
16 years 10 months ago #11042
by Darrol D8H
I can't recall his name, but he lived in the Scott City, KS area who had 2 DW10's which he had put #14 motor grader heads on them with turbochargers. He also put big weight boxes on rear, and had special final drive gears built to slow tractor down. Darrol D8H
16 years 10 months ago #11043
by CR
A DW 10 pulling a landplane...that must have fun trying to get that thing to turn around at the end of the field.
The discription of the landplane leveling land for irrigation is a little amusing, The landplane is the best way screw up a field and after about 10 - 15 years of landplaning a field and the field ends up bowl shaped with about 12" - 18" of dirt that must be cut from the edges of the field.
16 years 10 months ago #11047
by gauntjoh
Kelly, that's exactly what I had in mind. Guess it just has a drawbar / hitch, presumably no hydraulics to operate a ram for lifting, and presumably no PTO. Looks like the one in the top picture has a wight box ? which would make the rear view of the implement impossible, wonder why they did that, you'd think a DW10 would be heavy enough without extra weight, but clearly not as Darrol mentions 2 DW20s with weight boxes.
Very impressive pictures, thanks !
Time to create page: 0.186 seconds
