D2 Roller ID and compatibility
16 years 10 months ago #10573
by Jdnut
I have a set of D2 Rollers. 4 are double flange and 4 are single. All I can find on them for parts numbers are BERCO on one side of the mounting flange, and CR800 on the other side. There are the bushing style rollers.
My question, will the fit on a J series D2? They came off of a 5U.
Thanks!
Jdnut
Chris - Jdnut
Located in Stanwood, Washington
Collector Of:
Bucyrus Erie - 15B 20B 22B
Caterpillar - 8U D6, 3T & 4T D7
Kenworth - W900 & W925
John Deere - A's B's R's
Drott - 50 DC
Thank you received: 26
16 years 10 months ago #10589
by Jack
Hi Chris,
I checked my parts books. 5J and 5U used the same rollers on at least some of the series. They are to be arranged with single flange front and back, double flange in the middle two places. Rollers you have should work.
Jack
16 years 10 months ago #10630
by Jdnut
Thankyou Jack!
Chris - Jdnut
Collector Of:
Drott - 50 DC
Thank you received: 94
16 years 10 months ago #10631
by josh
One issue you might have a problem with is most of the U model rollers have a grease fitting guard cast into the roller which will not fit with J model rock or dirt guards, you will often see J models that have had the grease fitting holes in the guards torched out to a bigger hole to accomodate the later rollers, if your rollers are the lifetime type without a grease fitting it will not be an issue.
