Leaking injector pumps
16 years 11 months ago #10237
by railroadjoe220
I have a D47j that is leaking fuel where the pumps attach to the fuel injection housig.When I take the pumps off what what kind of gaskets do they have.Do they have to be readjusted when you remove them.
Thanks Joe
16 years 11 months ago #10243
Hi RRJoe,
There are no gaskets....uses part # 2A3349 ferrule seals....one for each pump.
You do not have to re-adjust the pumps to change the seals but it would be a good time to check them. Be careful that the plungers do not fall out of the pumps when you remove them.
16 years 11 months ago #10246
by SJ
OM, that number you gave was for the ferrule 2A3349 but the seal he needs to correct the leak is 2A3307 so he,ll need 4 seals.Joe make sure if the pump plunger gets out of the rack when you remove them then make sure the line (mark) on the pump plunger gear lines up with the line on the rack bar or the pump will be out of time & cause a miss or erratic running.
16 years 11 months ago #10249
Thanks SJ,
Forgot to look over at the separate assembly parts drawing where the seals are listed. It was kinda late:o
16 years 11 months ago #10250
by railroadjoe220
Thanks for the information,will call Cat to see if they are avialable.Can they be made out of gasket material?Tried to email you Ol maget but my email was returned.
Joe
16 years 11 months ago #10251
Hi RRJoe,
Should not be a problem getting seals, same ones used on later models.
Gasket material won't work......more like an "O" ring.
Ya, my email server service konked out and I had to switch. Should automatically forward but ?????. I'll send you an email so's you can get the new address:D
Time to create page: 0.148 seconds
