Question about width of 2-A blade
16 years 11 months ago #10051
by gwhdiesel75
Can a D2 with angle blade fit into a standard garage door (say 8 feet wide)? Am interested in this very minor question because I will be looking at houses with 2-car garages, and want to know if I should expect a D2 with blade to fit into one side of the garage. My D2 is a 5U series. GWH
Thank you received: 94
16 years 11 months ago #10052
by josh
8' 1-1/2" wide, so with the blade angled it should be a easy fit in an 8' door.
16 years 11 months ago #10061
by B4D2
George, if the inside dimension of the garage allows it, you could back in and then pivot the machine to swing the blade in the door at an angle. Good luck in the house hunt.
Thank you received: 34
16 years 11 months ago #10064
by Steve A
George
Around here a typical single car garage door on a Modern house would be 9 foot wide x 7 foot tall
I thought you just Moved a year or so back, Must be you found a woman that has other Ideas for you.
16 years 11 months ago #10065
by gwhdiesel75
Hi gang! Thanks for your responses. Two years ago I retired and moved to a townhouse in Colorado. This past June I sold the townhouse and moved into a condo that I have been renting. Now I'm starting to look for a single family home up in the mountains. I didn't know how wide a garage door would be and didn't have one nearby to measure. I might even be lucky enough to have room to build a pole barn to store my other tractors. I can always dream, can't I?
My thanks to Josh for the measurements of the blade, to Bruce for his kind thoughts and suggestion of how to get the tractor in a narrow door, and to Steve for the actual measurements of a modern garage door. Steve, I expect to see you in Woodland next year.
GWH
Time to create page: 0.153 seconds
