10 X 24 Are they hard to get? Any way to work truck tires onto this grader? Maybe Dayton open center 24.5 rims? I have a good stock of those size tires in 11.00. Thanks. LB
I believe those tires became obsolete shortly after that era of machines:( I seem to recall some rubbing problems on the older Cat graders if you went with 13x24's.
I have only found one source probably remaking the 10x24's and it's Denman Tire. Will provide a link.
