D7 3T Trans gear oil
Thank you received: 9
10 years 5 months ago #102622
by JohnnyJ
Good Day All. Attached pic illustrates. I am topping off trans gear oil and wanted be solid sure of this. Oil is about one inch from full when checked (screwdriver on dip stick). Wrench sitting on trans gear add?? Just wanted a lil input plz if someone has seen a lot of these and also exactly best type oil to add. Thank you all always.
Thank you received: 39
Thank you received: 341
10 years 5 months ago #102626
by edb
Hi John,
scan below shows you are on the money with check and fill points.
10 years 5 months ago #102632
by JohnnyJ
Gemdozer and EDB Thanks for commenting. I have three books (so far) and none had the express detail of the scan you provided. Is there a lubrication only type book for these. My 3T # is 20616.
10 years 5 months ago #102634
by edb
There is a grey covered Operation And Maintenance Instructions book (there is generally one for each machine and its attachments) that I have here that covers 7M1 to 7M9999 and 3T1 to 3T28058, Form No 10481-6. The -6 means later edition number with newer data added as deemed by Cat.
Generally the higher the - number the better the data to cover improvements to the product etc. I do not know if there are later editions than this one.
Thank you received: 620
Thank you received: 76
4 years 3 weeks ago #221978
by seiscat
The book you really need is the Operation and Maintenance Instructions. This is the capacities page from it:
I do have a copy for sale; if you are interested, send me a PM.
Craig
