I was wondering if you were using the D5 chain (6.9 in pitch) with the readily available sprockets in full, weld on ring or bolt on segment versions??? or you found some original (6.75 in pitch) chain that would require the matching sprocket or ring and much harder to come by.
We received the hubs in today. D-5 arrangement. The hubs are solid. Bolt on segments. I guess the shop had to change some seals to accomadate the different style hub. Awaiting the seals tomorrow... will keep you posted.
