Other questions - 3J4086
Thank you received: 409
17 years 3 weeks ago #9119
I should have asked these before. For D2 3J4086:
- what year was this tractor manufactured (and which plant?)
- what engine model would it have been built with, and what is the rated HP @ ? rpm
- what is low and high idle
- what oils are used (I think it's 30W everywhere except finals which take 80-90W)
- was it available with electric start for the starter motor?
- was the LaPlante Choat blade a factory option?
- anything else that you might like to pass on
Thanks in advance, Neil.
17 years 3 weeks ago #9123
by SJ
I don,t have the year made but they went in production in 1938 so it possible could be a early 40s tractor. The engine is a D3400 & the HP is 32 at 1525 full load. The high idle is about 1680 RPMs as high idle is 10% higher than full load.Low idle should be 550 RPMs. I can,t say what factory it was built in but guessing probably Peoria Illinois. The oils you mentioned sounds right & I believe the starters were optional (an attachment) back then according to a 7J D4 book of the same era so I,d think the D2 would be the same. Don,t know about the blade.
Time to create page: 0.116 seconds
