Cat 2 ton need help/info on engine
17 years 1 month ago #8265
by country
I have a really nice 2 ton cat, with original pressed pads, crossbar steering, air cleaner in tact, etc
it sat for 3 years inside my barn and now the engine is stuck
I pulled the pan, put some pressure on the crank with a bottle jack and still nothing. looking up inside #2 cylinder, I can see soem rust on the cylinder walls. I filled the cylinders with diesel fuel and will try to soak it out.
One of my questions is, if I have to pull the head, where can I get a head gasket set? How about piston rings, assuming they are standard.
thanks for any help
by the way, what is the approximate value of the machine today, I paid $3500 for it 3 years ago. ( with engine running)
Dave Newman
17 years 1 month ago #8280
by country
Thanks for the info
would you have the torque specs for the head bolts?
also, any idea on value? ( after it is running again)
Dave
Thank you received: 341
17 years 1 month ago #8281
by edb
Hi Country,
no specific tensions are given for these units but the attached should help.
Cheers, and Welcome to the BB.
17 years 1 month ago #8285
by Catmatt
dave,
where in philly are you located? I am from this area too, near norristown.
17 years 1 month ago #8300
by Catmatt
I live over near phoenixville. I am doing a job as we speak in newtown on 413 accross the street from the township building. How many cats do you have?
17 years 1 month ago #8305
by country
catmatt
I have the 2 ton, D2- 3J I think, a newer D3C hystat, cletracs: F, K20, 35, E-38, OC6-68, OC3, HG-68, John Deere: 2- MC, 450 loader, Lots of hit and miss and a few wheel tractors, plus a pile of army trucks.
what do you have?
Time to create page: 0.168 seconds
