D2 - Unusual (?) Hydraulic System
17 years 1 month ago #7904
by NZCat
Hello Guys - in my ongoing search for bits to hang off my D2, I have been offered a blade. It is pretty much a NZ made copy of the 2S blade (called a "Field Chief" blade here).
The bit I don't know about is the hydraulic system, the guy selling knows nothing about it except that it drives off where the generator normally goes, and has a small tank mounted close by. Was this very common (its not that common here in NZ as far as I can tell) ?? If anyone is familar with the set-up I'd love to know if it was sucessfull, and/or what the problems might be ??
I'm not able to view this gear as its a long ways away, hence what may seem dumb questions at this stage !!
Cheers - Foster
Foster Price
Southland, NZ
D2-5U #10200
17 years 1 month ago #7914
I've seen a few Cats with generator drive hydraulic pumps, some well done, some horrible, none that I would assume to be commercially produced.
I also run a 10 gpm, 2000 psi generator drive pump on an old Cletrac that I have. Works fine to operate a two hydraulic cylinder 3-pt hitch.
The trick will be matching pump to cylinder capacity for the correct blade movement rate.
Thank you received: 26
17 years 1 month ago #7916
by Jack
Pumps driven off timing gears arn't uncommon. I have one on a venerable Scoopmobile (Chrysler engine) that is still working well fifty some years later (fingers crossed here!) On Continental fourpoppers in forklifts the gear drive pump was considered something of a weakness. The iron idler gear gave out after a while, but forklifts do an astounding amount of pumping in the course of a day.
Cat has a pretty stout timing drive--force feed oil to the idler pin, good big gears. If, and I mean BIG IF, it's a well-built unit it should work fine. If the gear mesh isn't about perfect, it can wipe out a big part of your engine.
I'd say go pretty careful on it. I've seen enough engines full of metal shavings to satisfy any curiosity I ever had on the matter.
I don't need to hear about any more of them! Good luck.
Time to create page: 0.128 seconds
