pull type Cat grader
17 years 9 months ago #609
by kellyb
Hi, I have a pull type Cat grader, the SN is 8H500. We use it on the farm to run thru our field drainage ditches, it has a 12' moldboard and has been converted to hydraulic cyl. for the main control arms. I still have the Cat engine that ran the grader it has a SN of 4D1060 and I had it running a few years ago. It has a Fairbanks Morse magneto. The engine weighs 325 lbs.
I have surfed for detailed info on both of these and I cant find anything. If you have some info on year made, rare, etc. please let me know. Thanks.
17 years 9 months ago #610
by SJ
The grader is listed as a #44 grader & production started in 1937 according to the Cat SNID book but the engine year is blank & not listed as to what year it was first produced.That,s all I have on it.
Thank you received: 90
17 years 9 months ago #634
by bruce oz
hello kellyb,the cat 44 single frame grader was made from 1937 to 1942 and the weight is 8,170 lbs with power control fitted ,the one you have having a high number i would say it was built in the later years ,hope this helps,bruce oz
17 years 9 months ago #646
by SJ
Bruce, Of all the pull graders I,ve seen & been around here in my area I never saw one with a small engine on it like this one you pictured. Cat graders were as scarce as hens teeth to begin with as most were Galion & Austins & Adams pull behind graders.
17 years 9 months ago #653
by kellyb
Thats the best info Ive been able to get ever, can you tell me more or send be more pictures? Thanks alot.
KB
17 years 9 months ago #655
by Willie
Kelly when I get back home I'll lok for pics of mine and send yo many have had engine replaced with briggs or wis.
SJ ; what they did was put same setup as on No.10 or11 on a No.44 frame and power the controlbox with a little engine hanging down below it
17 years 9 months ago #668
by terrywelch_archive
Kinda like this one. We pulled this one out of the brush a few weeks ago. The engine was replaced with a Wisc years ago. Owner still has orginial engine. Note the optional siting pin above the front pedistal, a farmer add on. I have to try and help him get this going I will post some other pictures from the farm later. The number on this grader is 8H761.
Terry
17 years 9 months ago #676
by Steve Melton
Thanks for the info and the pics. on the Cat 44. I never knew they made a #44 with a power ubit on it. I learned something new.
I have a #44 that was my first ever restoration. It is like your first kiss, you never forget it. Thanks, Steve
