Part Numbers for A D-6 5R
Thank you received: 53
17 years 2 months ago #7644
by bboaz
Anyone with a parts book for a D-6 5-R that could give me some part numbers would be appreciated. This will be the 4 1/4 inch bore 4600 motor. I have a parts book bought off E-bay, but the seller had a problem with the Post Office. Been waiting almost two weeks to get a book from Ohio to Missouri. Anyway, I need numbers for the oil pan gasket, valve cover gaskets (2 ea), head gaskets (2 ea), and the two water inlet gaskets. One of the water inlet gaskets is the one on the left side of the heads for the fitting that goes to the pony motor and the other is the water inlet on the front of the head that connects the thermostat housing. I'm sure no one else has the problem of having to order things before the funds allocated for them get used for something else. I can order on line from the local cat dealer but I need the part numbers to be able to do it. Thanks
17 years 2 months ago #7646
Pan gasket RH 4B327, LH 4B328
Valve cover gasket (2) 4B291
Head gasket (2) 8B313
Thermostat housing to head gasket 2A3599
Pony water line connection at head gasket 6B145
Time to create page: 0.121 seconds
