- Thank you received: 504
Old Marget_ What is your web-site? My D-4 7U has been in my pole building the last four years. Went thru the ritual, new fuel filters, new fuel bypass spring and nipple, numerous bleeding attempts and I think today the pony failed? How do I verify pony has a broken rod or broken crank.You can add option # 3 if you have a mind to:)
It's possible to have both on the D4, just need to find space for battery/s or portable battery start. If you go the 12V route, the 6V pony electric start will operate fine.
Not a lot of option on the pony parts. Rings can be had readily aftermarket, pistons seem to be Cat only. Cylinder sleeves are aftermarket. Valves can be substituted. If you can make your own main bearings (T-something aluminum) you can save a few bucks and customize the thrust clearances. Seems machine shops don't know what to do with that block anymore. The crankshaft can be a cost killer, most are cracked, weld build up/repair is pricey. Be sure to check thickness and for cracks on the bottom of the cylinders where they all rot out or freeze burst before investing. Rod bearings are a Cat item. Camshafts and gears seem to go forever.
On the Direct Start, keep an eye on ebay. I've seen some pretty good deals there from time to time. I prefer the Delco 42MT starter for the fit reasons described on my website.
Need any more projects to help you with your retirement, just let me know:D
P.O. Box 9301
Peoria, IL 61612
(309) 691-5002
cat@acmoc.org
- Chris R
- Jason N
